Old 03-11-2007, 11:58 PM
gourdhedd's Avatar
gourdhedd gourdhedd is offline
gourdhedd
Default Re: researching-elec questions
Originally Posted by willy535
1)when wiring element,do you have to use connectors like on an oven,they seem to be ceramic type insulators.or just use connnectors.
2)i see alot of people use the standard 40amp contactor,like 4dd09 from mcmaster.will this suit me.i think i need 45amp but this one has 50 amp resistance and i see many use it.
3)what could i use for on/off switch.i will have main shut off for both legs,but at control box the on/off switch will be on one leg.what do most guys use. thanks in advance.......william
1. My experience with oven elements is that they have a screw connector on each leg which you wrap your incoming wire around and tighten. A few have some sort of proprietary plug-in connector which can be mounted to the frame of the oven, the wires of which are connected to your incoming wires with wire nuts, if nothing else.
2. Don't know about your McMaster contactor, but most contactors are given two ratings, FLA and resistive. The FLA (full load ampere) rating is for controlling motors which will , in fact, draw a much higher current while coming up to speed, or when loaded and their RPM is reduced by the load momentarily. Resistance elements, on the other hand, don't have the high starting or loaded current draw, and the so the rating is a bit less conservative. 50amps of resistance elements will only draw about 50 amps or a little less. A typical contactor may have a 40amp FLA rating and a 50amp resistive rating.
3.The ON/OFF switch should be wired in series with the thermostat and controls power to the contator coil only. The contactor coil has very minimal current requirements so the ON/OFF could be a light switch for a house (the cheapest) or a toggle switch.
Gary Brady
www.powdercoatoven.4t.com
