Old 03-12-2007, 05:21 AM
PoorOwner PoorOwner is offline
PoorOwner is on a distinguished road
Default Re: Conceptual stage: Electrical Questions
Hi, thanks for your suggestion, I do understand the role of ground and neutral. I am questioning whether I can easily build a 220V only system: 2 wires + 1 ground. The reason is that I am going to share the oven with my welder with the same plug, and the welder doesn't call for neutral. The problem is not the cost at all, I want a clean install that will work for both the welder and the oven.
Is it very hard to find a externally mounted motor @ 220V for the fan? Maybe a small blade or propeller at the end of the shaft..
The controller and contactor is available at 220V, and I probably won't have a window therefore no light, so the fan is probably the last piece of electronics that I know of right now.
