  #9 (permalink)
Old 03-12-2007, 01:33 PM
baz baz is offline
baz has a spectacular aura aboutbaz has a spectacular aura about
Default Re: Powdercoating cylinder heads
Originally Posted by Banditperformance
Personaly never done Alum heads, but they won't warp either. When you PC, you heat up the item evenly. With no clamping stresses like when a head is bolted down to a block. And the temp variance in a head when on the engine, from water jacket to cyl surface is extreme, far more than PC temps, so they will be just fine to coat.
thanks that makes sense .
i ve done many hd heads but never checked to see if it warped and i m about to do some v rod heads and i wanted to make sure before
baz
http://www.polissagepb.com
