Originally Posted by peterprv
How long should I expect the zinc (copy cad) solution to last before it's diluted? Is it ok to add fresh water to the tank to maintain the correct level?
The electrolyte itself should last indefinitely. It does not wear out or "expire" w/age.
If your liquid level is dropping due to evaporation, then yes, you can top it off w/more water.
But if your liquid level is dropping due to "dragout" (electrolyte remaining on the parts when you remove them), that needs to be replenished w/fresh solution.
Let your parts drain off well over the tank before going to rinse, and you won't lose much at all.
Sean
