Old 03-14-2007, 02:21 PM
defed defed is offline
defed is on a distinguished road
Default Re: polyisocyanurate (rigid foam) insulation
here is the response from the mfg:
The working service temperature of Celotex is -15 to + 100 degrees.
If used consistently outside these parameters, the board would start to
degrade.
i presume it is in degrees C since it is a UK company....which is not even the 300F i had read.
either way, with 2" of mineral wool between it and the heat, it should work as an additional layer of insulation.
