road to a new blast cabinet
Being that i am getting into more powdercoating and projects are getting bigger, I need to upgrade. I need a bigger pc oven, but before that i need a way to clean the parts to go into the oven. To remedy this problem I decided to build a better faster blast cabinet. I figured it is a big project so i broke it down into two parts: 1. the cabinet design 2. the media feed system. Since i am good with woodcrafting I figured I would tackle the harder part, the supply system. I have a sort of mentor that used the pa blaster plans to build his setup and swore by it. So naturally i bought the plans and started building. Best money i ever spent. Attached is a shopping list in excel format. I did leave out certain parts to assure that if you wanted to build one you would buy the plans from rob. Most of the stuff can be bought locally. THe hardest part was finding the 0-30 psi gauge.
