Originally Posted by pmac2002
Will a 3amp rectifier be better to anno than a battery charger?
I know from the calculator it says 6amps for x amount of minutes. Would the time be doubled if using 1/2 the amps?
thanks
Paul
A CC rectifier is the best to use.
That is 6 amps per square foot. You need to figure the surface area of the part to know how much current to use.
SS
