03-18-2007, 11:59 AM
Moderator
Re: Basic Anodizing questions
Originally Posted by OutlawPaintball
Where are you guys getting your blast media at? The local harbor freight had glass beads in 80 grit.What are you using AcidRain?
Several places in Austin can get blast media. Tractor supply, Grainger, AJ Rod.
Anyone using the utility sinks from home depot for a anodizing tank? its 23 gallons looks like it could be a good size sturdy tank.?
I used the sinks for a while. They work well for a 20 gal tank.
I think i am going to buy that cooler just because i don't think i will ever be able to keep the temps below 80 degrees her in Texas.
You will need a chiller. I'm about 50 miles from you and have already dealt with that problem.
SS
