Old 03-18-2007, 08:04 PM
sswee's Avatar
sswee sswee is offline
Moderator
Default Re: another rookie question for you seasoned vets....
The 3A rectifier from Caswell will work much better than a battery charger.
Use 1 part battery acid to 3 parts distilled water.
The anodize time required is directly dependent on current density. A 3 ASF (amps per square foot) is the lowest CD you want to use for anodizing. Any lower and the pore size will be too large to hold dye.
SS
