Peter:
We need more info. You say everything is just right, but haven't given us any numbers to go by, so all we can do it guess.
- How big is your part?
- How much current are you putting into it?
- Are you using original or new formula electrolyte? They DO use different temps & currents.
- Are you using the "brightener"
You haven't mentioned brightener at all, so I assume you are not using it. In this case, parts will
always come out dull gray. You have to acid-dip them afterwards to get the silver white color.
You say acid dip doesn't work. What kind of acid, and at what % concentration?
What are you expecting it to look like? If you want a bright silver reflective surface, like commercial nuts & bolts, you need to use either brightener, or chromate. Without either of those, you'll always get a "matte" finish.
A fine grey foam grows around the piece and the wire it is hanging from
That's a good indication that it is indeed plating.
To confirm, throw the part into a 5-10% muriatic acid solution. Within 5-10 minutes it should be fizzing away, stripping off the zinc. If it does NOT fizz, then it did not plate.
There are now some pieces of this foam (looks like miniature lava) floating in the tank.
That's an indication of insufficiently clean part.
I adjusted the voltage to around 1.5 volts
Ignore the voltage, adjust only the current.
Sean
