  #8 (permalink)
Old 03-21-2007, 06:13 PM
seanc seanc is offline
Zinc Plating Guru
Default Re: Copy Cad beginners problems
Peter:
I'm using new formula copy cad solution at 30 centigrade (88 fahrenheit)
The new formula calls for 110ºF. I have never tried it at less than that, so can't say how much of a difference it makes.
but I'm looking for a dull cad type finish on the larger items anyway
In that case, even when it has plated correctly, parts will be dull gray, and you'll need an acid dip to turn them silver/white.
Heres before & after photos, w/out brightener:
Before and After
Used 1.12 amps for a part that was 8 square inches
That's right on for the new formula.
Acid dip is 5% hydrochloric.
How long should I expect to dip the part to remove the grey foam that grows during plating?
That should do it within a few seconds! The change in color is quite obvious (if it's plated properly), and you just leave it until it stops changing. In my cases that's never more than 5-7 seconds or so. I've never actually timed it.
Sean
Seans Zinc Plating page
