Old 03-22-2007, 03:27 AM
Banditperformance Banditperformance is offline
Default Re: How to do multiple powder colors on these wheels
Originally Posted by baz
if i get this right he is doing the lip and top of fins chrome .
that means the grooves between the fins will be black ,if he does the black first how would you suggest masking inside the grooves ?
i ll have to try that half baking the chrome ,i might get better results .
thanks
Ya, I had my layers backwards on that I guess. So then, do the chrome first, then clear it. Easiest to do whole rim. Then, mask, spray black, half bake, till Flow Out. Then remove tape and final cure.
Any time you spray chrome, you need to clear it right away, it's 2 coats or nothin. It will start oxidizing immediately, and the longer it oxidizes, the duller it gets. I allways bake chrome half time, then shoot clear coat(or a transparent clear) hot, when part has cooled to just below 200*F
Dan Pesonen
Forest Grove, BC Canada
Personal motto:
