Rab:
I have been adding brightner at the start of each plating cycle as recommended in the manual
NOOOO!
You do NOT add brightener every time. You add it ONCE, and when parts start to plate less brightly, add a bit more. This may take many plating cycles, it just depends on total sq-inches plated.
Can you have too much brightner ?
If so what would the effects of this be ?
Yes. If you're already almost out of brightener, then you've used far too much.
I do NOT know what the consequences would be though. Contact Caswell tech support and ask them.
In the meanwhile, if you filter the solution, that should remove most of the brightener.
Sean
