Re: stainless welding rod to hang parts
No! Only 3 things can go into the acid tank, aluminum, lead and titanium! If your at the welding supply shop and if your parts are small you can you MIG welding wire the kind I use is a 5xxx series alloy and works real well for my little parts. Another option is go to the local farm supply store and pick up a spool of electric fence wire. I got a spool 1/4mile long of 14gage pretty cheap.
Later,
Tim
