Old 03-24-2007, 10:40 PM
acidrain's Avatar
acidrain acidrain is offline
acidrain has a spectacular aura aboutacidrain has a spectacular aura about
Default Re: Chemical etching???
If that is an anodized graphic, it will take more than just etching the part... you'll need to cut a mask and apply it during the dye process of the ano job.
You don't want to simply remove the ano in a pattern using etch and masking... it will leave the metal unprotected.
I do things.
