Originally Posted by XK120DHC
Dan;
A hundred years ago, before the advent of hundreds of vendors supplying thousands of identical "custom parts" for Choppers (Harleys), I, and a number of other folks, had the shock that mounted on the "Springer" Front End (fitted to "Knucklehead" hawgs) chromed.. It's a good thing it was done "for looks" as the chromed shock did little or nothing to dampen the "bounce" of the Springer... especially at freeway speeds (70+).. of course I didn't know if the shock was functioning before it was chromed, or not, but I guarantee you, it wasn't after it was chromed.. Something to keep in mind when thinking about the functional outcome of chroming a new/working snowmobile shock..
Charles,
Thanks for the response. I guess my main concern was the fluid leaking and contaminating the solution. The shocks that I would be plating are ski shocks and are for adding a little stability to the skiis and are pretty much for show on these old junkers. I do wish the aftermarket would come around a little quicker on some of these items. I guess it's going to cost me $600 to $700 to find out.
Thanks again,
Dan
