Old 07-11-2003, 06:30 PM
mdarr mdarr is offline
mdarr
Default Copper Anode Usage
I have the 4 gallon triple chrome setup. I have a separate tank for flash copper, bright copper, nickel and chrome. The kit only included two 4" X 8" copper anodes. I assume I need two more since I'm using both flash and bright copper. Is this correct? In the mean time, can I use the same set of anodes for both flash and bright copper if I rinse them off including the bandages they are in first before putting them in the other solution? thanks for any input.
