Old 04-06-2007, 01:07 PM
acidrain acidrain is offline
Default Re: Rig for Anodizing Pen Barrels?
Yes, you will want to ano all the parts at once for a good color match.
Your connection approach doesn't sound good... I would use Ti wire (if you can find it) and bend into a kind of inside clamp. Then it can be shoved into the barrels without blemishing the outside.
Calculate all of the surface areas, and multiply by your target CD for the required amps.
They should all turn out exactly the same as long as all the parts are the same alloy.
Instead of sand, use very fine glass beads to give a satin silvery finish... sand will embed contamanants.
