Thread: Curing question
Old 07-12-2003, 12:54 AM
adambond adambond is offline
adambond
are you using an IR (infrared) oven. if so its probably shortwave and they typically only heat the part surface quikly while taking longer to heat the sunbstrate . but you are probably using a regular electric oven im guessing, which evenly heats very well. maybe its cheap powder. ive had powder that wouldnt even resist rubbing alcohol.
ADAM (just trying to get a higher rating) BOND
