Re: LCD method
We all use the LCD method... I'm running 6 amps per sq. ft.
Are you familiar with the 720 rule? There is a stickied thread describing it above, and about 8 posts in, there is a calculator, which figures out required amps and time to build the desired mils.
If you are having one or two parts in a batch that are not turning out well, it may be that they are a different alloy.
I seperate out the different alloys, and run the 5xxx and 6xxx for full time, but run the 2xxx and 7xxx for 3/4 time.
