Re: LCD method
Yes I use the 720 rule now, I use to use the 900 rule a few years ago. I never have very much patiences figuring out sq. ft of parts though. So the LCD method is around 6 amps per sq. ft?
Acidrain, I seen some photo's of your ano tank, what do you use for air agitaion? I use two fish tank air pumps hooked up on each side of the same plastic tube running around the bottom of my tank. Another question, what distance should parts be away from the cathodes?
Thanks again everyone,
Shane
