  #10 (permalink)
Old 04-11-2007, 07:15 AM
mpierich mpierich is offline
Default Re: anyone in CT/NJ want to help me out?
Originally Posted by soccergk
ok i read through the buffing manual. I am still confused about which wheels i should be buying, I have 1 cotton sewn wheel i was using with the white, is that the right type of wheel? Should I get the blue compound for after the white? I am using an electric drill, will that get the job done?
Cotton wheels OK. Spiral sewn or loose, depending on how hard you want it to cut. I like treated (yellow) bias cut for emery, but it's aggressive. After emery, I go spiral/white, then loose/white or flannel/white. Slower is better for the last step. Keep everything clean.
If I want to pimp it out I might go to flannel/red but it's too glitzy for my taste.
