Some parts orange, some gold
What did I do wrong? The two largest pieces turned out orange, the four smaller ones turned out golden. My first thought was to much current density (approx 12amps CD) caused dissolution. But from what I've read about dissolution the parts would have been chalky & the coating would probably 'wipe' off. Mine didn't have that.
Basically here is what I did that has always worked in the past-
degreased parts with simple green & hot water
rinsed
tumbled parts for about 3 hours w/treated corn cob media
degreased again with simple green & hot water
rinsed w/r.o. water
anodized for 65 minutes @12CD (temp was 66-69')
R.O. rinse
neutralized (baking soda & water)
R.O. rinse
dye'd in orange @120' for 15 minutes
R.O. rinse
sealed for 20 minutes in a steamy hot cooler bath was @180'
(been successful in the past)
The only thing different is my Current Density. Normally I go for 6-9 amps. All parts had excellent connection using aluminum wire. I'm speculating they weren't all the same grade aluminum.
Thanks in advance,
Gary
