  #13 (permalink)
Old 04-11-2007, 02:00 PM
Ready2Dye Ready2Dye is offline
Ready2Dye is on a distinguished road
Talking Re: Rig for Anodizing Pen Barrels?
Originally Posted by destroyer125
If your going to use paper clips, Id suggest going and buying some long gloves, You will need to grab your pen pieces out of the bottom of the tank.
LMAO
You're pretty funny destroyer, I gotta admit I'm still laughing. Screw it... I'm putting that in my sig. The one I have now is actually from the thread with the kool-aid LT was talking about; cuz the dialouge in there is SOOOOO funny.....
.....ANYWAYS....
Originally Posted by LadyTiger
i just discovered and printed out an older thread that should really be called "how not to anodize" () where the guy tried using grape kool-aid to anodize his parts red. while i was skimming over the plethora of advice, i encountered a reference to the "720 rule"? do you have a good link explaining what that is?
(PS--the guys changed their mind again and ignored what i had to say about stainless steel paper clips. thus our sulphuric bath is full of little bits of iron now from where the paper clips were completely eaten through. i laughed at them. they're now going to go out and purchase some more Al wire for us to use.)
So LadyTiger, the guys in your group ignored the idea and used the clips anyways?
.....we are a STUBBORN breed!
About the parts not comming out good, were all the parts connected with only the paper clips? If so, when they corroded the connection was shot, and no further ano'ing would be possible.
About the 720 rule; you must have looked at the thread twenty times and not noticed it. It is a "sticky" on every page of "Anodizing Questions" and its called.... Anodizing calculations(720 Rule) and inside there you can find a link to an online calculator were you plug in the surface area and desired thickness with whatever current density you want (6ASF works fine). If you want MORE info on the 720 rule go here.
HTH
REDRIVER: You're still using the cool aid as a dye supplement aren't you? Avoid this...
quadster: Kool-aid? Hummmmmmmm............ I havent even tryed Rit yet yet.....I could clean out a bunch of cabinet space....
mcaswell: Cool Aid? RIT? ...Will someone pour me a large JD to steady my nerves?
