Re: Question: Calculating nickel in Electroless kit
The reason we need to use Electroless N. is because everything we do has to be perfectly original. Ferrari (Which is the majority of restorations we do) used electroless nickel on lots of different components through the 50's and 60's. Most of the cars we restore are for competition in shows and originality is the single most important aspect.
It looks like we are going to order the mini electroless kit to play around with, and then upgrade to a 15 gallon version if everything works out. So hopefully we can get an idea of how the calculation technique works for us. If we decide to go with the larger EN kit, I will give you a call and we can discuss the titration kit details. I just wanted to know if a titration kit was available. Thanks for the response Lance,
-Nick
