Aluminum cathodes
Just wondering who is using aluminum cathodes. From what I under stand you can use 1 sq foot cathode to every 3 sq foot anode. Is this the same for lead, does the aluminum produce better results?
One last question from what I have read it should be 6063T6 if you are using aluminum what are you using?
