Re: Starting an oven and have some Q's
I would use the smaller elements and set it up so that you could manually shut what you don't need when you are at half capacity. Use 1 contactor for each element and you will have the control you want. It will add a few more bucks but from what you discribed, sounds like a sweet set up, and is pretty much what I am building. Spend the few extra bucks and have the control you are after and you won't be sorry..................
