Old 04-21-2007, 09:57 PM
ashcroft01's Avatar
ashcroft01 ashcroft01 is offline
ashcroft01 is on a distinguished road
Default Re: rust coming thru plating
goldmankc,
Chances are the brush plating technique did not allow for a thick enough coat to prevent further corrosion.
To help combat issues like this, especially when brush plating, it may be wise to start your bare metal with a coat of Copper first. This will aid in the prevention of moisture seeping through the Nickel and back into the steel. It also helps the Nickel adhere and creates a thicker overall plate.
Brush plating leaves an incredibly thin deposit compared to immersion plating.
The amperage requirements are self adjusting on the brush plating system.
Best of luck,
Curtis Ashcroft
M and C's Plating & Powder Services
