  #8 (permalink)
Old 04-25-2007, 12:47 PM
seanc seanc is offline
Zinc Plating Guru
Default Re: MY Power Supply Has Me Confused - can't control Current
Originally Posted by smithb98
So then I notice a tiny little wisp of smoke coming from the big resistor .... It started to turn dark grey and was incredibly hot
Good heating elements!
Put in the .47ohm resistor and it worked great though it only went down to 3 or 4 amps and then defaulted to .40
So it looks like your power supply needs at least 1/2 ohm or more to operate.
but I'm not sure why you said I shouldn't see more than 3 volts if I am plating at 6 amps with a 1ohm resistor. Wouldn't my volts be 6?
You're right, I didn't explain that fully.
You're never likely to see more than 3 volts at the plating tank (from anode to cathode). Any inline resistor will have it's own voltage drop. The 2 voltages, added together, are what the power supply has to furnish.
eg, if you take 2 resistors of equal value in series (actual value doesn't matter, as long as they're equal), and connect them to a 12v battery, each resistor will drop 6 volts. It's this voltage that you use in calculating the wattage.
Unequal value resistors will each see a different voltage, depending on the actual resistances, which will sum up to the applied voltage.
Do they make a 1ohm resistor rated at 100watts? 100 watts=10amps x 10 volts?
You bet they do, but you won't find it at Radio Shack.
If you're in or near a big city, you might find an electronics supply house where you can get one quick.
Otherwise, shop online. They're not cheap, nothing that big ever is:You might find cheaper by searching surplus stores.
though re-reading your post, you pointed out the obvious. If I'm not having problems, say, below 6 or 7 amps, I would only need a 1ohm resistor rated to handle 36 or 49 watts.
You got it! Figuring this stuff is not cut-n-dried, may take a little experimentation. That's why higher wattage is better, it may be overkill, but you won't have to wonder if it's enough.
Sean
Seans Zinc Plating page
