  #17 (permalink)
Old 04-28-2007, 12:08 PM
jrow jrow is offline
Default Re: Can greaseless do the job? Pleasehelp
Originally Posted by CASBEN
okay so i started sanding the rims with 80 grit paper on a small palm sander.
This sandpaper, 80 grit, is to course. It's going to take a lot of labor to remove the 80 grit scratches before you start to polish! Start with a sandpaper grit that closely matches the aluminum you are polishing. I would suggest 220 grit, if that doesn't cut it try going back to 180 grit.
I was able to succesfully get the pits/scratches out except for a couple of deep ones.but doing this took me quite a bit. is there a faster way thati could sand then other then a palm sander?
Try using the greaseless compound.
John
