Thread: Fan questions
Old 04-29-2007, 09:37 PM
JTW37's Avatar
JTW37 JTW37 is offline
Caswell Platinum Member
Default Re: Fan questions
I've seen fans mounted in the side at the bottom with the blades inside the oven. I've seen them mount at the top inside. Mine is mounted outside and I ran a fan in a box with intake from the inside out and pushed it back in via a tube that runs down the wall, inside toward the bottom. I guess they all work fine. Just a matter of where you want it to be and how.
