  #8 (permalink)
Old 07-21-2003, 08:04 PM
Hemi-T's Avatar
Hemi-T Hemi-T is offline
Hemi-T
Try coating a similar part without using the pretreatment and see if you get the same results. I would be suspicious of something that says it works for paint and powder coating. They're different beasts. Any contamination could potentially cause outgassing. The brake cleaner I use is extremely volatile, and vaporizes completely in seconds even without heat, but I still preheat to outgas aluminum parts anyway. Good luck!
Hemi-T
