Re: Self cleaning
Jtw37
You mentioned that you had a couple of sites where elements can be bought reasonably, but you didn't put down where?
If I can just get the bottom element to work I'd be happy and I will work on getting the top units into the inside later.
I wired it up today and a transformer started to smoke. I had the top of the oven off (one of those totally flat kind) no elements exposed.
There is a flat circuit board about 3 X 7" and on it there was this coil of copper wire that was wrapped until it started to fry.
I can't find a serial number or Model number anywhere on this unit I've turned it (literally) upside down. The wiring paper in with it was under the top burner and said "diagram # 8104P176-60" I think I saw the year 1998 somewhere on it too. Anyone know where I might find the Magic Chef numbers on this (might be 98 unit).
Thanks
