Old 05-11-2007, 01:55 PM
chromo chromo is offline
chromo
Default Battery acid, Sulfuric acid?
I was reading something some where, maybe my old Caswell pdf manaul, that mentioned using a more pure sulfuric acid I think. Like buy straight acid and dilute to around 1.7SG, and it mentioned battery acid is normally 1.29SG I think.
Something like that anyway, I'll have to read eveything again a few more times.
So I checked with the local Napa here, very small town, they don't have sulfuric acid other than battery acid and when they looked it up they could not find it to be ordered either. I did not ask how much for the battery acid or if they had it, I should have.
Now I don't recall exactly what I was reading, but it's something I was planing to do! Either for a pickle, anodizing, plating, cleaner, or something but it was in the realm of metal finishing and the Specific Gravity was stronger than battery acid.
Is everyone just using battery acid? Or are you mixing straight acid and distilled water? If mixing the straight stuff, who sells it and about how much is it costing you?
Heck online I could not even find battery acid at Napa or Autozone just now!
I figure if I am going to set up all the polishing stuff, I might as well do all the finishes.
