Old 05-12-2007, 12:32 AM
sswee's Avatar
sswee sswee is offline
Moderator
Default Re: Battery acid, Sulfuric acid?
Most all are using battery acid. Sulfuric acid by itself can be gotten at chemical suppliers. The battery acid is usually easier to get and cheaper. There is no benefit to using straight sulfuric. You would have much more work to dilute down to the proper ratio. Lab grade acid is normally diluted by weight. The procedure for battery acid is diluted by volume.
SS
