Old 07-22-2003, 09:34 PM
Unless the piece you're anodizing is very small, like 2 or 3 sq. in. surface area, it sounds like your anode connection failed. The result is almost no anodize on the work (not enough to dye properly) but the anode wire is anodized wery well. If the wire was still on the work when you dyed it, I'll bet it took and held the dye.
