Originally Posted by atroxr7
just wanted to say thanks for spending the time on this, its probly trivial with the temp controller ill be using, but it gives me a head up on what to expect. Also great for a future project i was thinking about... annealing oven
I may be of some help to you with regard to desired temperatures. Most of my paintbooths are 24' long, 11' high, 14' wide. They achieve 160 flat line in 4 minutes bringing in 10,000 CFM of 25 ambient air. These small ovens are toys to me. Call me and let me know what you would like to accomplish and i'll steer you in the right direction. You are probably using 220v electric heat or infra red. Qiet, but tooo sloww. You could probably use a small propane burner and get 600 degrees very fast, and with very accurate temps.
Eddie
