Originally Posted by chromo
FiReBReTHa
You only use it once cause it's easier and faster to toss it than clean it. If you use the same metal hanger for spraying it will get dusted also, then use it to bake and it gets baked also. So next time you try to use it the powder coat stops you from getting a decent ground unless you clean off the coating to bare metal again.
Thanks for the tip!
While trying to find a solution we found picture wire.
200 ft for 5 bucks!
