Old 05-17-2007, 01:35 AM
outcastzeroone outcastzeroone is offline
outcastzeroone
Default Re: got some questions (dont we all)
I found this
http://www.shellab.com/store/product.php?productid=1043
Now the oven I curently have like I said is a krups. It is a total of 1600w. It has 6 elements. 3 on top, 3 on the bottom and it will alternate between powering the top and bottom for a more even heat.
what I am most worried about is that I may over heat one area in the new oven and not heat up the other parts enough and end up with an uneven heating. the elements in the Krups are 3/8" thick (quartz covered rods) and only 11 3/4" long. With that coiled one I found I hope I could snake it around the top and a second on the bottom to make sure I get an even heat all over the oven. Some of the parts I plan to coat will be fairly close to the limits of the new oven I am making so I want to make sure it comes out ok. I havent ordered anything yet, just reaserching parts and such.
