Stripping Nickel Plating
Hello Everyone,
I would like to know the most easist way to strip Nickel plating without using my rectifier. If I need to I can use the rectifier? All help is appreciated. I need to strip nicekl off old brass hardware and bathroom hardware which is brass underneath? I have used muriatic acid with brass in the past and it I notice that it will destroy the brass if not watched.
