Old 07-24-2003, 03:52 AM
aermakov@rogers.com aermakov@rogers.com is offline
aermakov@rogers.com
Default MUST Un-zinc part (Copy-Cad)
This is probably for Mike...
Is it posible to remove excess zinc from a part by reversing polarity? My timer broke down and the part plated for 49! hours instead of intended 24 minutes. Needless to say that I will be buying a set of anodes from you, but also need to know the best way to remove the wildly thick layer of zinc. Thanks.
Andrew.
I have it sitting in reverse mode right now, small piece of anode had picked up some zinc already. I will let you know what will happen next.
