Aluminum Foil Masking
We often use aluminum foil to mask large areas. We use tape for the parting edges and to hold the foil in place. Much quicker and less expensive than trying to mask a larger area with all tape.
There are aluminum foil tapes too, but typically expensive and bad about adhesive transfer to the product if run through the cure cycle.
-Scott
J. Scott Moncrief
Manager-Engineering, R&D
Livingstone Coating Corporation
