How much should I charge?
"few small peices off of my quad to coat them in black. im wanting my front A-arms and a couple of other really small bits done. the a-arms are the biggest part. they are about 10 inches long and about 8 inches wide by 1 inch thick. they are just steel tubing welded into triangle shapes. its the front suspension from a honda 400ex if you want to google some images of it. i can even sand blast them at work before sendign them to you to save you some time/effort. the other bits are small things like brake/clutch lever, brake fluid caps ect ect. gloss black would be what im looking for. i can have them all prepped so that you only have to wipe them down and coat them."
Thanks!
