  #19 (permalink)
Old 06-03-2007, 07:20 PM
SLOSteve SLOSteve is offline
SLOSteve is an unknown quantity at this point
Default Re: New To The Forum W/Question About Replating Bezels
Mark,
Are you sure you knew what I was saying after reading it 12 times? LOL! That was embarrassing
Okay.....so far as a power source I have a battery charger which has 3 volt/amp settings. One is 6v-6amp, second is 12v-2amp, and the third is 12v-6amp. It has a meter that shows constant charging status as well. Will this be sufficient if I run the charger on a 600w light dimmer to control the amps?
Also, some of my bezels aren't really that bad and I don't think they need to be stripped in order to plate. Today I sanded one of the not-so-bad ones and there was no pit, it sanded smoothly. In that case would I just clean then chrome plate over the existing plate. Will it stick and cover the scratches as well?
My kit should arrive by the middle of the week I hope. Now I need to make room in my garage to set up. That should be fun with 4 cars to move around. LOL !
As always your advice is appreciated !
Thanks,
Steve
