  #20 (permalink)
Old 06-03-2007, 08:50 PM
KCV6's Avatar
KCV6 KCV6 is offline
Default Re: New To The Forum W/Question About Replating Bezels
Steve,
I'd definately use the salt water rheostat method. Hook the battery charger to a 12V battery (optional, it just keeps a trickle charge going between plating cycles) and then run from the battery to the salt water bucket. and then to the item. Refer to page 50 of the Caswell manual when it arives, it is all explained there. Do as the manual says and plate a scrap piece first, copper pipe lengths are good. Don't do it every time as you will just be wasting the chromium in the chromic acid.
With the alkaline strip method I suggested, it will only remove the chrome. It will not affect any underlying plate or substrate, so this will be ideal for the bezels you have that are in reasonable condition. They can then be lightly sanded with 800 grit wet and dry to remove any scratches. Remember the less imperfections you have to start with, the less work required between plating applications.
The solution is a weak mixture of Caustic Soda and tap water. 6%, so if you have 60 grams of Caustic Soda for every litre of tap water. check the label on the draino crystals and make sure it is caustic soda (sodium hydroxide). go to your local steel supplier and get two 6 x 8 pieces of 304 stainless steel to use as cathodes. You can also use these as rheostat plates, you will just need to attach some hangers for one edge. You will see what I mean when you look at page 50.
Are you also getting the flash copper to strike coat the items first? Ooops, just looked, forgot the tripple chrome now comes with the flash copper. Is way too early.
Cheers
Mark
