Re: Can I PC this head?
first problem you might have- is the valve seats loosening up with the heat.- I can't say for sure with that head- you shouldn't but some heads have such issues. Another thing it do you plan on milling the head before ore after?- the same with all the other machine work? I'd recomend coating it and then have the machine work done as some aluminum heads have a dendencie to warp with heat if they're not bolted down/assembled, ect. other than that you should be good to go.
Save the trees- burn Rubber!
