Old 06-06-2007, 01:54 AM
speeddemonrodsteration's Avatar
speeddemonrodsteration speeddemonrodsteration is offline
Default Re: Can I PC this head?
Originally Posted by Banditperformance
that head should not warp, because you are heating it evenly, and only to 400.
I'm not saying that it will warp- but it is a very strong possibility. I worked in a machine shop for many years and when we had an aluminum head that was really warped- we'd bolt it to a straightnig plate and bake at only 350*, I know that combustion temps are alot higher than that but the head is assembled and evenly torqued down at the time, therefor it isn't alowed to warp. I'm just saying don't be surprised if you have to mill it afterwards- which I'd recomend anyways since the head gasket mating surface has been blasted!
Save the trees- burn Rubber!
