Re: Copy Chrome Problems Need Help!!!!!!
When plating with the copy chrome you need to plate for about 90 minutes to get a thick plating. If the parts are coming out with a slight haze on the item and it buffs off easily then it is fairly normal. If your parts are coming out consistently dull then brightener should be added. The brightener will deteriorate over time and needs to be replenished.
