Old 06-06-2007, 01:34 PM
cbrooks's Avatar
cbrooks cbrooks is offline
Caswell Inc Staff
cbrooks is a glorious beacon of lightcbrooks is a glorious beacon of lightcbrooks is a glorious beacon of lightcbrooks is a glorious beacon of lightcbrooks is a glorious beacon of lightcbrooks is a glorious beacon of light
Default Re: Copy Chrome Setup Need Help Please
When setting up your copy chrome tank the directions on the crystals state to heat, allow to cool then add the brightener. If after copper plating you notice any defects then buff them out before proceeding to the copy chrome. Thoroughly clean the part again making sure that it passes the water break test before going on. Your amps should be set using one amp per 32 square inches. Then the plating time should be for 90 minutes to get a good plating thickness.
Craige Brooks
Have A Web Site?
