Old 06-06-2007, 06:54 PM
CarWiz's Avatar
CarWiz CarWiz is offline
Caswell Platinum Member
Default Re: What temp for Electroless Nickel solution?
Originally Posted by cbrooks
The ceramic and titanium heaters are preset for 210 degrees F. They are more than adequate to heat the electorless to the operating temperature.
Mine must be broken then. Where is this "preset" located? If I turn around and leave mine for a few minutes (more like 45), the solution will be at a raging boil. (692' ASL)
